I am planning on mounting an amp under the passenger seat. After taking the seat out and removing the adjustment wire, a buddy had a couple pieces of 1/2" x 1/2" x 1" Delrin made. We drilled holes in these pieces and mounted them to the bottom of the seat. Then we connected a wire to the latch mechanism, ran it through both pieces of Delrin, and back to the other latch. The key is that the wire only needs to work in tension, so it can be pretty flimsy as long as the Delrin doesn't shred it (round the holes) and it is tight when you start out (we soldered the wire, and left one of the pieces of Delrin free while soldering, then attached it afterwards to put a little tension in the wire). Hopefully I can get some pictures posted if anybody wants to see.
