Posts: 2,489 |
are the flex pipe and cat one connected piece?
1998 T-Red CSVT 3.0L
Posts: 750 |
Posts: 2,489 |
well it seems like my flex pipe is damaged, cat is fine, and the only way to fix it is to replace both of them, which doesnt make sense since everything, including the flex pipe is working fine. is it possible to just fix the flex pipe?
Posts: 1,085 |
Originally posted by Nate S: well it seems like my flex pipe is damaged, cat is fine, and the only way to fix it is to replace both of them, which doesnt make sense since everything, including the flex pipe is working fine. is it possible to just fix the flex pipe?
Yes....cut it off, weld on a new one.... Go to ... http://www.vibrantperformance.com/vibrantperformance.html Click on Custom Exhaust Then Click Flex Couplings Bingo...
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 2,489 |
Originally posted by WestCoastAjax: Yes....cut it off, weld on a new one.... Go to ... http://www.vibrantperformance.com/vibrantperformance.html
ok so you can cut it off...the shop i went to said that i would have to replace both the flex pipe and the cat, because they were connected, even though the cat was fine...i was like...uh...do you think im stupid, im not replacing the cat if its not bad...
Posts: 1,085 |
Some folks have to make a living others are out for blood....
2012 Lotus Evora
Posts: 22 |
Originally posted by WestCoastAjax: Some folks have to make a living others are out for blood....
BEEN THERE BEFORE, the funny thing is that midas said i needed a new one too and needed to orderr it so i said i'd be back, whent to ford got it fixed free under the federal 8/80,000 warranty and never herd back from midas seeing when i wanted to get it instaled, guess they never ordered it like they said they would and call me
Posts: 1,085 |
The steel ones -stock- are available at muffler shops, I went down and they showed me one. Too small for me, good for stock.
2012 Lotus Evora
