1. Remove the air conditioning hose retaining nut.
2. Remove the power assisted steering hose retaining nut.
3. Remove the coolant hose retaining studs.
4. Remove the dipstick tube and lifting eye retaining bolts.
5. Remove the dipstick.
6. Remove the exhaust manifold heat shield.
7. Disconnect the camshaft position sensor electrical connector.
8. Remove the camshaft position sensor.
Installation
1. To install, reverse the removal procedure.
