Page 1 of 3 1 2 3
#80666 09/24/01 06:03 AM
I think I heard of people putting 6x9's in their doors? I have a 98 SE, and I'd like to upgrade my 6x8's to the 6x9's, but will they fit? Thx.
#80667 09/24/01 11:37 AM
I
I
im not sure if they'll fit, but Im also not sure thered be much ,if any, of an improvement from an aftermarket 6x8 and and aftermarket 6x9. You may want to check into getting a set of 6.5 components and a small amp, it sounds sooo much better
-In
#80668 09/24/01 05:08 PM
6x9's will fit easily. You just need to drill new holes and either remove (like I did) or shave down the metal handles in the rear doors.
'98.5 silver SVT, #6226 of 6535,
24mm AAM "aussiebar", KKM intake, custom y-pipe w/ high flow cat,
custom cat-back w/ Magnaflow race series mufflers w/ 4" tips, Bosch
+4s, FMS 9mm blue wires, IAT mod, Bullit fuel door, 35% tint all
around, APC clear sidemarkers, PIAA 510 driving lights, Cuzo
headlights, "carbon" sail panels, chopped shifter w/ Richbrook knob,
OBX pedal pads, "Bluepoint" Key Largo HU, Pioneer TS-A6955 6x9 3-way speakers in the doors, Precision Power PPI2240 amp, Xtant X410 10" sub in bandpass enclosure.
#80669 09/24/01 06:23 PM
ok, so 3 questions at this point.
what sounds better, 3 way 6x9's or component 6 1/2's, and do the tweeters fit in the front sail panels, aannndd, where do I put the tweeters in the rear? at a glance, the bar between the rear side windows and the rear window looks good.
#80670 09/24/01 06:31 PM
I
I
6 1/2's sound better.. the tweeters will fit in the front sail panel (thats where mine are) not completly flush however. and I took my rear speakers out for better front stage. But if you do want them in (because of whiney back passengers) id buy acheap set of aftermarket 6x8's and run those off of your HU.
HTH
#80671 09/24/01 06:49 PM
I think I've decided to go with the Pioneer ts-a6985's. Am I going to have any problems with the depth of the speaker (magnet)? I heard someone say the windows dont roll down, and my amp puts out 50 watts RMS, nominal, 150 peak, and these speakers are rated at 60/260. Is my amp going to have any problem driving them?
#80672 09/24/01 06:53 PM
You may need to make or buy a spacer. I believe Metra makes a spacer.
The amp will be fine.
#80673 09/25/01 12:43 AM
You will need a spacer for those, buy one or make one, you will need at least 1/2 inch.
take a ride, take a shot now
Black 98.5 SVT (sold)
Silver 99 SVT (work in progress)
#80674 09/25/01 02:13 AM
(1) 6.5" components sound infinitely better than 6x9s (of similar cost/quality)
(2) Depends on the size of the tweeter. You might be able to flush small tweets. Large tweets surface mount.
(3) Don't waste your money with rear speakers. It'll just mess up the front soundstage to have a strong musical presence (other than bass, which has no point source) behind you. Inspinout's got the right idea.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#80675 09/25/01 11:31 PM
am I gonna get a comparable amount of bass? I like it LOUD most of the time, with two 6 1/2's compared to 4 6x9's?
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
