rk2k2
I am quite happy with the look (in person) but I had hoped they'd be a little more subtle (darker). If you are looking for lighter than stock, these are definitely not for you as the wheel/tire is 9 lbs heavier than stock E1 with 195/50 KDW. My calculations (using a wheel offset calculator) turned out just right- inside clearance of teh 18" wheel is almost exactly the same as stock! Tire comparison calculator indicated about .6" dia diff, but the .3" higher ride is slightly noticable (maybe cuz the 40's don't flex as much as the 50's?)
