Window seal weather stripping?
n811
Hi Folks:
Aside from the scrounging the yards, does anyone know where to get replacement weather seal material where the bottom of the window meets the door (black molded strip ~ 1" wide, "whisker strip")? Mine is corroding from the inside out and causing a few small scratches on the glass.
Thanks,
Nate
Junk yard. Don't just yank them out either because they will bend. Use a flat screwdriver and work your way down the moulding as you gently pull up ;).
