Is there some evidence to support the first statement regarding the IMRC? What would cause it to burn out? As far as gunk, short drives, not warming up the engine and dodgy oil change intervals would likely be more to blame.Driving so the secondaries never open is a great way to gunk up your butterflies and burn up your imrc.
It's also a poor way to run a nice high rpm motor.![]()
Boring.Is there some evidence to support the first statement regarding the IMRC? What would cause it to burn out? As far as gunk, short drives, not warming up the engine and dodgy oil change intervals would likely be more to blame.
I understand the desire to spin these engines into their higher rpm ranges but it isn't really necessary to do so in order to get down the road with any real alacrity. Shifting between 2500 - 3000 rpms works just fine.
Karl
From your join date, I'm surprised by your statement. There have been many instances, in the old forums, of what I said. The secondary butterflies will gunk up no matter what you do, but if they never move, they will be difficult to move when you finally want them to. It's best to regularly clean them to keep this from happening. If you don't clean them... and if you never drive so they open, your IMRC motor can burn out from the resistance of the sludged over butterflies.Is there some evidence to support the first statement regarding the IMRC? What would cause it to burn out? As far as gunk, short drives, not warming up the engine and dodgy oil change intervals would likely be more to blame.
Karl
Yeah, a :troutslap: for me. However, as I mentioned in another post, gear shifts in the rpm range you mention will get you a nice exibition of speed ticket just about anywhere inside city limits. FWIW, I might take it to 4 -5K on a freeway onramp once in a while but it really isn't necessary (and likely impossible) in most traffic situations where I live unless it's three in the morning and no one is on the road.From your join date, I'm surprised by your statement. There have been many instances, in the old forums, of what I said. The secondary butterflies will gunk up no matter what you do, but if they never move, they will be difficult to move when you finally want them to. It's best to regularly clean them to keep this from happening. If you don't clean them... and if you never drive so they open, your IMRC motor can burn out from the resistance of the sludged over butterflies.
If you don't go over 3000rpm, I think you'd be better off with a diesel![]()
Also, is it wise to double clutch when downshifting with the MTX-75? and do all the gears have synchros?
Thanks,
Ada
When you shift at 3k, where does that put your rpms in the next gear? Do you never get on the freeway? Cruising on the freeway, my rpms are usually 3800-4000rpm.I shift @ 3K every gear, unless I'm merging into traffic, then it first through third @ redline.
Oh reeeally. Rev limiter is 6750 my friend.When you shift at 3k, where does that put your rpms in the next gear? Do you never get on the freeway? Cruising on the freeway, my rpms are usually 3800-4000rpm.
In the end.. shift points really depends on how much gas your giving it -- not a universal static number. For me, I'm usually shifting around 5000, but regularly see 7100.. but if I'm trolling around a residential area, around 3500-4000.
Maybe for youOh reeeally. Rev limiter is 6750 my friend.
When you downshift, do you give it gas to bring the revs up? You might also want to check all your mounts/roll restrictors to make sure they're in good condition.thanks for the info guys. I was wondering because sometimes when I downshift, I get a jirkey feeling when the clutch and engine meet. What is the cause of this? Am I letting out the clutch too fast? Also sometimes, I get a little jerk feeling when shifting from 2nd to 3rd. Is it due to me not giving it enough gas, or letting the clutch out too fast?? Iam stumped!
Thanks
Adam
