I just finished replacing my water pump. Things went pretty smoothly, but I just turned the car on as a test and the belt started smoking. At first it was a small amount of smoke but it didn't stop increasing in volume. So I shut it off.
The belt snapped a few seconds later. This is the belt recommended by BAT and I bought it along with my metal impeller water pump. The new belt did seem significantly tighter - so tight it was really hard to put on, whereas the old motorcraft belt was extremely easy to take off.
Should I install the old belt, or does this seem like it's a symptom of a larger problem? I know no one can give me the absolutely correct answer so opinions are very welcome :help:
