macantley
right now i have the RCA outputs on my cd-player feeding the signal to the OEM amp which im assuming is made by JBL, the sound is surprisingly good for a OEM system but not 100% up to my standards. Im wondering if ford makes any other car's that have a plug and play amp that would sound alot better, or provide more power?
also for anyone adding a sound system to the contour, how did they route the power wire from the battery to the trunk?
and last but not least, im planning on building a bandpass box and port the port out through the hole in the rear deck, i figure a 4" or 6" port would support a 8" or 10" woofer, but im not real sure, if i run a sealed box, im going to build a custom box that actually mounts to the rear deck and seal it right up against the rear deck with caulking and probably put a 10" woofer in the rear deck.
right now im using a alpine 7892 headunit, the factory amp behind the glove box, and if i have to ill just put an aftermarket amp in its place.
for now though ill probably be running a diamond audio CM3 10" woofer with dual 4 ohm coils i can run it from either a hollywood sound RHV2000D or an american bass 1800 amp.
both will be more than enough to power a single 10" woofer.
im looking for good sound quality without giving up too much trunk space.
worst case senario, i have 5 clarion 8" woofers, 2 tang band 8" woofers, 2 tang band 6.5" woofers and also two tang band 5.25" woofers.
im going to put alittle bump in this car
matthew
matthew
