Unorthodox UDP concerns (can it be installed on a 96, and which belt)?
96_NoVA_Zetec
Alexandria, VA
Hello fellow CEGers,
I have recently stumbled upon an underdrive pulley that I had purchased several years ago. It is the Unorthodox Racing P/N# 0203106 REV N/A. I have attached the installation instructions. Since I am somewhat cash-strapped (having been laid-off two weeks ago), I was wondering if this pulley can be installed on my 96 (non-VCT) 2.0? Further, does anyone in CEG-Land have the correct Gates belt number?
Thanks,
Shamun
If you're a 95-97 zetec owner and you have AC, the belt to use with this UDP would be the NAPA 060721 belt or any 6 rib V rib belt measuring 13/16" width x 72-5/8" length or in MM's 20mm x 1845mm.
Deyes2 and Lavell,
First of all, THANKS! for responding. I did not mention that I have A/C in my original post. Does that change the answer(s) that I received?
MANY thanks,
Shamun
Ditto on the NAPA belt. BTW, you should run an ODP on your alternator too. I was going to get one from xzxtuner but I think I found an identical one on eBay for the same price but 1/2 shipping cost. I'll let you know how it goes. It was only like $24 shipped.
you dont need an ODP. It may help with performance, but i've never had a problem with running stock pully's and a crank UDP.
