Turbo Build Pics - 2002 MTX Cougar
looks good...I like where you put the distribution block and the one you used ;)...btw, I'm running an IMRC as well with no issues.
You have the same Tsunami Fused Dist Block? Did you have trouble with yours at all? Mine has been great, but now all of a sudden the volt readout is having some issues. Not sure if it has something to do with the current draw when starting the car or not?
I dont see why not run with an IMRC? Most people experience low end and idle issues when you remove the secondaries anyway.
Yep, looks like a similiar one, but maybe a different model...I've had problems with mine as well and have replaced it once...I think it has more to do with the heat from the engine...I don't think they were designed for that type of environment...
I saw the one comment about the IMRC, but folks here using them don't seem to have any problems...there are some pros and cons, but I believe leaving the IMRC in is the way to go...
