CSVT#49
Addicted CEG'er
Alright so I've been researching more and more on the traction bar setup I want to design and build. Although I am seeing conflicting information with designs. Full-Race who I had originally contacted designs their systems to have the front mounting of the traction bar in-line with the lower control arm (LCA) mounting. They do this so that the traction bar pivots about the same axis as the LCA; and does not bind the suspension. This makes sense. However it is not really possible to do this on the Contour and still allow full lock to lock steering as the tires will collide with the traction bar.
Doing research on other designs I came across a Lakewood traction bar setup for the Focus, which I actually discovered from an OLD thread on the CEG Archives... (Link) The discussion started around preloading the setup. Well The Lakewood design places the pivot points of the the traction bars much farther inward from the pivot point of the LCA. I would think this would cause the suspension to bind as it would not follow the same arc. I do like the fact that the Lakewood design ties the rear side of the front subframe to the cross brace of the traction bar setup. I plan to do the same with my design as I feel it will allow for less flex in the subframe mounts.
Thoughts on the pivot points? Below is a picture of the Lakewood Focus setup. Also here is the link for the Lakewood installation, Link
