just a heads up to everyone based on what happed to me the last few days.
first off, I have personally confirmed that the zetec (95 contour) is non-interference engine. however autozone says different.
I checked the Gates web site and it suggests checking the belt every 120k miles.
This number is high. When I first changed the belt at 104K the tensioner was about to split in half. Could see the crack coming from the center almost all the way to the outside 180 degrees apart.
my car now has 222k and the tensioner failed this time.
I would recommend that you change the timing belt and all pulleys every 100K miles.
