green1999csvt
Had an issue where temperature gage was reading low, would occasionally come up a tiny bit, then drop back down to low. I replaced the thermostat (the old one fell out in 3 or 4 pieces) and put it all back together. Now the gage needle is well below low and just lays there like the power is off. Yes I plugged it back in to the temp sensor!
My question is how do you check this out? Is temp sensor a variable resistance device I can read with a multimeter? How can I give a dummy signal to the gage to get it to go full scale? Will 12 volts give it a signal or kill it?
Thanks
Thanks
