ruehling2
Where would I hook the wires up to install an after market tach.
Are the conectors all there all i would have to do is change them out no wirring
For a 97, the wiring should all be there. you just need to swap out the clusters.Are the conectors all there all i would have to do is change them out no wirring
im in the same boat as u. However, i have an early 95 model that has the mechanical cable driven speedo, so i don't think mine has any of the wiring for a tach. I haven't confirmed it tho
Is it possible to keep the cable speedo and put it in a later cluster? I've never taken apart a cable speedo cluster before.
That's because you didn't get a fully-compatible cluster. If you have a pre98, you need to get a pre98 Misty cluster. 1998, then you need a 1998. 98.5+...98.5+....
