hi guys,
I need your help figuring this out. I bought a set of SVT cams to upgrade my Duratec.... I removed my stock cams and tried to install those I received but they didn't fit under my cam caps.
Here are the pics of the cams I received. These do not fit my Cougar's Duratec. The ring pointed with red arrows is larger and do not fit my cam caps. Its diameter is 2 or 3 millimeters larger than my stock cams. Can you tell me what cams these are???
http://www.newcougar.org/gallery/showimage.php?i=4161&catid=newimages
http://www.newcougar.org/gallery/showimage.php?i=4169&catid=newimages
http://www.newcougar.org/gallery/showimage.php?i=4153&catid=newimages
http://www.newcougar.org/gallery/showimage.php?i=4137&catid=newimages
http://www.newcougar.org/gallery/showimage.php?i=4145&catid=newimages
I bought these cams from a CEG and NECO member who is pretty much sure these cams are from a CSVT 2000. If you guys have a set of CSVT cams, please, can you tell me the measures of that ring?
I have to add that my stock cams have 36 theet chain wheels and those I bought have 42 theet chain wheels but this is not the issue. The issue is the diameter of that ring pointed with red arrows on the pics that is way bigger (at least 2 millimeters) than the same ring on my stock cams. Are these cams CSVT cams and, if they are, any idea why they do not fit? Please help me finding an answer!!!
If it can help these are the measures of the cams in the pics:
the wheel is 42 theet and 4.1 inches in diameter. The rings that do not fits are 1.88 inches or 47.5millimeters (diameter) and 0.2 inches or 5.1millimeters (thickness).
Thank you guys for any help you can provide.
Rudy
Rudy
