I have a feeling this is a dead-end question, but is there anywhere to buy the gears to the sunroof motor? The gear that seems more often to need replacement is the one driven by the worm drive from the motor. At least that's the one worn in my car. Ford must have had a vendor manufacture the gear. Lousy plastic/nylon gear that prob gets stripped whenever there's a jam or some resistance.
The other solution I thought of is to find a hand crank handle that would bypass the motor & fit on the turning shaft directly.
Any comments appreciated.
Thanks
Thanks
