My daily job is installing radios and audio equipment in cars..I happen to be Mecp certified, if it matters any.. from the looks of it the amp that you have is an amplifier that can be from a "shaker" system that is found in mustangs.. cant tell from the pics if you have the "input" pigtail that would come from the factory harness that sends the "music signal" to the amp to amplify.. from there it goes to your subs..IMO the amount of trouble it would cause you to install it wouldn't be worth the the sound it actually creates.. they re normally a higher ohm resistance than a sub you can purchase at a store, and theyre RMS watts is low as well.. youre better off going with something else.. you can probably find one 10 in speaker cheap that can sound better than those 3 speakers right there..
