montrese04
So long story short i have the truck stated in the title. the factory speakers in the doors have some type of external amp on them. I'm swappign the 6x9 in the door for after market and am having an ugly time with the whole event but whatever, on to the pics. Tell me what you think i can do with all this old stereo stuff i found laying around my house over the years
busted and disgusted pioneer HU (with one RCA output in back smh)
Either this 900 watt rockford Fostgate for the sub
specs 40 watts RMS x 4 at 4 ohms
75 watts RMS x 4 at 2 ohms
150 watts RMS x 2 bridged output at 4 ohms
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
Or this older phoenix gold for the sub
list of specs Specs
Features:
Into 4 ohms Stereo @ 12.5 Vdc (IASCA/USAC) 18 x 4
Into 4 ohms Stereo @ 14.4 Vdc 75 x 4
Into 2 ohms Stereo @ 14.4 Vdc 125 x 4
Into 4 ohms Bridged @ 14.4 Vdc 250 x 2
Minimum Speaker Load, Bridged 2 ohms
Minimum Speaker Load, Stereo 1 ohm
Fuse Size, Stereo 4 W / Stereo 2 W / Bridged 60 / 80 / 80 amp
Dimensions, Chassis (inches) 15.00 L x 9.00 W x 2.25 H
Dimensions, Overall (inches) 16.00 L x 10.00 W x 2.25 H
Bass Boost 0 to +18dB @ 45 Hz
Crossover Slope 24dB per octave
Input Voltage Range 10.5 to 15.5 volts
the sub is a 12 inch pioneer premier
the 6x9 are some cerwin vegas
specs are 6" x 8" or 5" x 7" HED Series 3-Way Triaxial Speakers
Power Handling: 100W Peak / 50W RMS
Overall Frequency Response: 35Hz-22kHz
Injection molded pearl mica polypropylene woofer with titanium-nickel alloy coating
1-5/8" Titanium-nickel composite cone midrange for increased vocal definition
1" Titanium-nickel composite dome tweeter
Sensitivity: 90dB
whatever this ugly thing is i dont have a clue how to work it lol
and is this for my tweeters in the A pillar. cuz im going to get some decent ones off the net
list of specs Specs
Features:
Sensitivity: 90dB
