Lanky R
Hello
I drive a 98 SVT with 42,XXX miles and I started to notice this problem at about 35,XXX miles. When I let off the gas or apply the gas abruptly the car lurches back and forth a lot. Now I know that all manual trasmissions do this when you mash the gas very quickly or let off from full throttle very quickly. But this happens much more easily, so easy that i have to TRY so the car wont do it. Even in cruise control in 4th gear the car will lurch on slight acceleration. Now I've had multiple other manual contours including 96 zetec, 98 duratec, and 2000 svt and none of the other cars drive like this at all. The 2000 SVT feels like a completely different car. It also takes the 98SVT a little more time for the clutch to grab when starting off, it doesnt grab like the 2000 SVT or even like the 98 SE did, and if i do let the clutch out quickly (not dropping the clutch, Ive never driven the car hard) it grabs a little faster but has a "chruchy" sort of feel. I have done multiple little tests to see if my clutch is slipping and It never seem to be, I can go full throttle in 5th gear at 25mph and revs go up slowly with the speed. My question is.. Is the clutch or flywheel bad? or is some other issue?
Thank you guys in advance!
-Ricky
-Ricky
