squeek when depressing clutch pedal
S2Knott
Sandwich, Massachusetts
started last week, theres a little squeek noise when i push the clutch in, it still grabs fine and is not slipping or enaging at a different position...
does it just need to be lube or could it be the throw out bearing or what?
thanks, i asked one of the mechanics at my shop and he said the same thing, i felt it in a 2 tsx's today and a TL so then i mentioned it. he said most of the time you it can just be sprayed/lubed or whatever.
When it rained, it sounded like my clutch assembly made a squeeking noise when I depressed the clutch pedal. Turns out it was my shoe rubbing on the SVT floor mat! What a relief that was.
Karl
oddly enough after this thread popped up, tonight mine has a tiny squeak. I'm blaming it on the below freezing weather.
