Side Markers.
LGR Mystique
I just bought some side markers for my 98' Mystique, i was wondering if it is possible to hook them up so they come on with the headlights, but also work with the turn signals?
I did see that, but it goes bright only when the signals come on, and dim with the headlamps. I want is bright with the headlights, and on/off with the signal
go to do alittle searching on the old forums ... I believe if you connect to the constant 12v and the turn signal 12v and the side marker will be on bright all the time and blink with the turn signal ... possitive ground ....
