I have a 99 Contour 2.0 manufactured 10/98. When i replaced the serpentine belt I found the old belt extremely tight. The tensioner was right at it's compression limit. I replaced the idler pulley with a new one and it's diameter was the same as the old. Put on a new Gates K060827 serpentine belt. When I put it on I had to compress the tensioner completely to it's limit and force the belt over the water pump pulley, it was very tight. I called Gates technical support and they assure me this is the correct belt. The bearing on the new water pump I installed is making a racket from being over tight. I would appreciate any insight as to what is going on. Is this the correct belt? Am I missing something and routing the belt incorrectly? Thanks for any help or insight.
This diagram matches the sticker under the hood and as far as I can tell the pullies on the car match this
2001 Ford Focus Zetec Accessory Drive
