hotdimmes
If anyone is curious as to what you get when you order rocker panel replacements from rockauto.com, here is what they look like mocked up on the car. Keep in mind the sill tabs on the replacements are sitting on on my aluminum sill plates so they are sitting a little high and I don't have the pinch weld section pushed in against the original. As mentioned in other posts, these don't come with end caps for the wheel wells. The fit looks pretty decent otherwise though.
Unfortunately, these just replace the rocker skin, I'm pretty sure the actual internal structure is starting to rust out pretty good and unable to support a jack on the rear side:
