RockAuto closeout parts!
zorrex
Enjoys the Abuse
South Amherst, MA
Hey guys, I just got an e-mail from RockAuto advertising a bunch of closeouts. There are some STELLAR deals! Keep in mind I copied and pasted this from my e-mail, and I have a PRE98 ZETEC ATX. Keep this in mind when considering buying parts! Some things might not be compatible.
RockAuto Catalog Wholesale Closeout Part Listings : 1996 FORD CONTOUR GL 2.0L 1989cc 121cid L4 FI (3)
Belt Drive
Part Type: Serpentine Belt
Manufacturer: GOODYEAR
Part No: 4060685
Notes: Poly-V; Exc AC
Regular Price: $17.53
Closeout Price: $8.98
SAVE 49%
Only 14 Remaining!
Part No: 4060735
Notes: Poly-V; W/AC
Regular Price: $23.79
Closeout Price: $12.18
SAVE 49%
Only 6 Remaining!
Manufacturer: DAYCO
Part No: 5060735
Notes: Multiple Accessory, w/A.C.
Regular Price: $26.79
Closeout Price: $13.82
SAVE 48%
Only 2 Remaining!
Body-Interior
Part Type: Power Window Motor
Manufacturer: MOTORCRAFT
Part No: WLM60RM
Notes: Front Right
Rear Right
Closeout Price: $22.79
Only 2 Remaining!
Part No: WLM61RM
Notes: Front Left
Rear Left
Regular Price: $78.79
SAVE 71%
Only 14 Remaining!
Manufacturer: A-1 CARDONE
Part No: 42362
Notes: Front Left; Supplied w/Gear;Supplied w/o Regulator
Rear Left; Supplied w/Gear;Supplied w/o Regulator
Regular Price: $61.79
Closeout Price: $35.79
SAVE 42%
Only 1 Remaining!
Brake/Wheel Hub
Part Type: Brake Pad
Manufacturer: AUTOSPECIALTY / KELSEY-HAYES
Part No: 2864801
Notes: Front Economy Semi-Metallic; Value Maxx Semi-Metallic
Closeout Price: $8.64
Only 1 Remaining!
Part No: 2864803
Only 1 Remaining!
Part No: 2566101
Notes: Rear Premium Organic; w/4 Wheel Disc Brakes Plus Series Organic w/ABS
Closeout Price: $10.98
Only 1 Remaining!
Manufacturer: RAYBESTOS
Part No: PGD661
Notes: Rear; Organic; Originally Equipped With Organic
Regular Price: $24.89
Closeout Price: $12.94
SAVE 48%
Only 6 Remaining!
Part No: 2266101
Notes: Rear Organic Brake; w/4 Wheel Disc Brakes; Axxis Deluxe Plus w/ABS
Closeout Price: $14.11
Only 1 Remaining!
Manufacturer: WAGNER
Part No: PD661
Notes: OE Replacement; Organic; Rear
Regular Price: $28.79
Closeout Price: $15.09
SAVE 48%
Only 2 Remaining!
Part No: BR66B
Notes: w/o Wear Sensor; Integrally Molded; Organic; Rear
Regular Price: $30.79
Closeout Price: $16.38
SAVE 47%
Only 11 Remaining!
Manufacturer: BENDIX
Part No: MKD648
Notes: Front
Regular Price: $34.79
Closeout Price: $17.47
SAVE 50%
Only 15 Remaining!
Part No: 1464812
Notes: Front Original Equipment; Pro Series Semi-Metallic
Closeout Price: $18.21
Only 3 Remaining!
Part No: PGD648M
Notes: Front; Semi-Metallic; Originally Equipped With Semi-Metallic
Regular Price: $37.79
Closeout Price: $19.65
SAVE 48%
Manufacturer: ACDELCO
Part No: 17D661M
Notes: PAD KIT,RR DISC BRK DURASTOP SEMI MET
Regular Price: $40.79
Closeout Price: $20.79
SAVE 49%
Only 1 Remaining!
Manufacturer: GUARDIAN / ONE SOURCE
Part No: 65648
Notes: Front
Closeout Price: $20.89
Only 1 Remaining!
Part No: BR23B
Notes: w/o Wear Sensor; Integrally Molded; Semi-Metallic; Front
Regular Price: $40.89
Closeout Price: $21.79
SAVE 47%
Only 2 Remaining!
Part No: 17D648M
Notes: PAD KIT,FRT DISC BRK DURASTOP SEMI MET
Regular Price: $47.79
Closeout Price: $24.79
SAVE 48%
Only 8 Remaining!
Part Type: Brake Shoe
Part No: 3069611
Notes: Rear Premium
Closeout Price: $11.97
Only 2 Remaining!
Part No: Z736
Notes: Rear; 9 x 1-11/16" Brake
Closeout Price: $12.47
SAVE 48%
Part No: R696L
Notes: Rear; Rear Drum Brakes
Regular Price: $34.99
Closeout Price: $13.94
SAVE 60%
Only 6 Remaining!
Part No: Z696
Notes: Rear; 8 x 1-15/32" Brake
Closeout Price: $18.23
SAVE 48%
Only 13 Remaining!
Part No: 696PG
Notes: Rear
Regular Price: $44.79
Closeout Price: $23.79
SAVE 47%
Only 18 Remaining!
Part No: 696L
Regular Price: $52.99
Closeout Price: $26.79
SAVE 49%
Only 1 Remaining!
Part Type: Caliper
Part No: BRC108RM
Notes: Front Right
Regular Price: $55.79
SAVE 52%
Only 1 Remaining!
Part No: BRCL108RM
Notes: Front Right
Regular Price: $77.79
Closeout Price: $37.79
SAVE 51%
Only 1 Remaining!
Part Type: Drum
Part No: 52125429
Regular Price: $19.90
Closeout Price: $10.35
SAVE 48%
Only 1 Remaining!
Part Type: Drum Brake Adjusting Spring Kit
Part No: 18K838
Notes: SPRING KIT,RR BRK SHOE ADJR & RTN DURASTOP; COMBI AXLE INCLS HOLD DOWN AXLE KIT
Regular Price: $16.18
Closeout Price: $8.34
SAVE 48%
Only 1 Remaining!
Part Type: Drum Brake Hardware Kit
Part No: HK4091
Notes: Rear; w/Front Disc & Rear Drum Brakes; 203.2MM X 36MM - w/o ABS
Closeout Price: $7.26
Only 1 Remaining!
Part Type: Hydraulic Hose
Part No: HB81076
Notes: Front
Closeout Price: $6.59
Part No: 18J1243
Notes: HOSE,FRT BRK DURASTOP; w/REAR DRUM BRAKES
HOSE,FRT BRK DURASTOP; w/REAR DISC BRAKES
Closeout Price: $7.33
Only 1 Remaining!
Part No: HB81373
Notes: Rear; w/4 Wheel Disc Brakes; w/ABS
Closeout Price: $7.49
Only 7 Remaining!
Part No: HB81374
Notes: Rear; w/Front Disc & Rear Drum Brakes; w/o ABS
Closeout Price: $7.52
Only 7 Remaining!
Part Type: Master Cylinder
Manufacturer: DORMAN
Part No: M390409
Notes: w/Power Brakes; Bore = 1"; w/ABS
Regular Price: $73.79
Closeout Price: $38.79
SAVE 47%
Only 1 Remaining!
Part No: M81093
Notes: 25MM - w/ABS
Closeout Price: $46.79
Only 1 Remaining!
Part No: 13046
Notes: Without Anti-Lock Braking System
Closeout Price: $51.79
Only 2 Remaining!
Part Type: Wheel Cylinder
Part No: WC131262
Notes: Rear; 2.0L; 8" Brake; 7/8" Bore
Regular Price: $11.02
Closeout Price: $5.77
SAVE 48%
Part No: W81044
Notes: Rear; w/Front Disc & Rear Drum Brakes; 22.2MM - w/o ABS
Closeout Price: $5.97
Part No: 34112
Notes: Rear Left; Rear drum brake 8"
Rear Right; Rear drum brake 8"
Closeout Price: $18.56
Only 12 Remaining!
Part Type: Wheel Cylinder Repair Kit
Part No: KW81013
Closeout Price: $4.01
Cooling System
Part Type: Radiator Upper Hose
Part No: KM2909
Notes: Upper
Regular Price: $11.04
Closeout Price: $5.31
SAVE 52%
Only 2 Remaining!
Electrical-Connector
Part Type: Air Bag Connector
Manufacturer: STANDARD MOTOR PRODUCTS
Part No: S691
Closeout Price: $2.66
Only 1 Remaining!
Electrical-Switch & Relay
Part Type: Wiper Switch
Part No: DS583
Notes: REAR WIPER
Only 1 Remaining!
Emission
Part Type: PCV Valve
Manufacturer: FRAM
Part No: FV349
Regular Price: $1.70
Closeout Price: $0.86
SAVE 49%
Part No: V317
Regular Price: $2.88
Closeout Price: $1.54
SAVE 47%
Only 12 Remaining!
Engine
Part Type: Camshaft Seal
Manufacturer: TIMKEN
Part No: 3774S
Regular Price: $5.61
Closeout Price: $2.94
SAVE 48%
Only 7 Remaining!
Part Type: Crankcase Breather Element
Manufacturer: FRAM
Part No: BA8112
Notes: Crankcase air filter
Regular Price: $4.07
Closeout Price: $2.07
SAVE 49%
Only 7 Remaining!
Part Type: Timing Belt
Part No: 40258
Regular Price: $22.79
Closeout Price: $11.67
SAVE 49%
Only 1 Remaining!
Fuel/Air
Part Type: Air Filter
Manufacturer: FRAM
Part No: CA7738
Regular Price: $6.52
Closeout Price: $3.31
SAVE 49%
Part Type: Fuel Injector
Part No: CM4804
Notes: 968F-9F593AB,AC; 4 required per vehicle
Only 1 Remaining!
Part Type: Fuel Pump
Part No: EP443
Notes: PUMP,FUEL (ELEC)
Closeout Price: $73.79
Only 3 Remaining!
Ignition
Part Type: Camshaft Position Sensor
Part No: PC66
Regular Price: $29.79
Closeout Price: $15.97
SAVE 46%
Only 17 Remaining!
Part Type: Ignition Control Module
Part No: LX253
Regular Price: $150.99
Closeout Price: $80.99
SAVE 46%
Only 1 Remaining!
Part No: F1945
Notes: MODULE,IGN COIL
Regular Price: $171.79
Closeout Price: $91.79
SAVE 47%
Only 1 Remaining!
Part No: F1957
Notes: MODULE,ELEK IGN CONT
Closeout Price: $106.99
Only 1 Remaining!
Steering
Part Type: Rack and Pinion Complete Unit
Part No: 3618714
Notes: GEAR,STRG (REMAN-RACK & PINION-POWER COMPLETE) 195/65R15 OR 205/65R15 TIRES
Regular Price: $156.79
SAVE 48%
Only 1 Remaining!
Part Type: Tie Rod End
Part No: 45A0727
Notes: ROD,STRG LNKG OTR TIE -; RIGHT HAND
Closeout Price: $16.79
SAVE 52%
Only 2 Remaining!
Manufacturer: MOOG
Part No: ES3300
Notes: Frt Strg; Outer; RH
Regular Price: $45.79
SAVE 50%
Only 1 Remaining!
Manufacturer: MOOG
Part No: ES3301
Notes: Frt Strg; Outer; LH
SAVE 50%
Manufacturer: MOOG
Part No: EV320
Notes: Frt Strg; Inner; w/14" wheels
Regular Price: $63.79
Closeout Price: $29.79
SAVE 53%
Only 3 Remaining!
Suspension
Part Type: Shock Absorber
Part No: AS1098G
Notes: 2 required per vehicle; Rear
Regular Price: $81.99
Closeout Price: $39.79
SAVE 51%
Only 1 Remaining!
Part Type: Stabilizer Bar Link
Manufacturer: MOOG
Part No: K8852
Notes: Frt Susp; Standard Design
Closeout Price: $11.38
SAVE 52%
Only 10 Remaining!
Manufacturer: MOOG
Part No: K8744
Notes: Frt Susp; Problem Solver; greaseable link kit
Closeout Price: $12.37
SAVE 48%
Only 6 Remaining!
Part Type: Strut Assembly
Manufacturer: MONROE
Part No: 801983
Notes: Front
Regular Price: $57.79
Closeout Price: $29.89
SAVE 48%
Only 2 Remaining!
Part No: 71983
Notes: Front
Regular Price: $72.79
SAVE 48%
Only 5 Remaining!
Part No: 503193
Notes: STRUT,FRT SUSP
Regular Price: $70.79
SAVE 45%
Only 2 Remaining!
Part Type: Strut Mount
Part No: 0781012
Notes: Front
Part No: 501142
Notes: MOUNT,RR SUSP STRUT
Only 1 Remaining!
Transmission-Automatic
Part Type: Output Shaft Seal
Manufacturer: NATIONAL
Part No: 3622
Notes: Ford CD4E 4 Spd. Automatic Transaxle
Regular Price: $9.90
Closeout Price: $5.23
SAVE 47%
Only 5 Remaining!
Part Type: Torque Converter Seal
Part No: 4189H
Notes: 4 Spd; AX4, AXOD
Regular Price: $8.44
Closeout Price: $4.42
SAVE 48%
Only 6 Remaining!
Wiper & Washer
Part Type: Wiper Blade
Part No: 82209
Notes: BLADE,WSW PASSENGER SIDE; 20 IN 510 MM
Regular Price: $7.81
Closeout Price: $3.92
SAVE 50%
Only 1 Remaining!
Part No: 83205
Regular Price: $10.34
Closeout Price: $5.19
SAVE 50%
Part No: WW2009
Notes: Right
Regular Price: $9.81
Closeout Price: $5.20
SAVE 47%
Only 1 Remaining!
Part Type: Wiper Motor
Part No: WM712RM
Notes: Remanufactured; Front
Closeout Price: $25.79
SAVE 67%
cant believe this. rockauto sends me an email after ordering telling me they sold out of what i ordered.:mad:
Someone probably ordered it just before you did. You don't get billed until it ships, and it probably didn't get set up to ship until the next business day after you ordered it (today).
