So my front e brake cable snapped and I got a replacement lever/cable. I have it connected to the rear cables but I couldn't get the handle up far enough to bolt it down(not knowing you can release the mechanism to get more slack), so I removed the rear calipers....
I have the slack I need now, but I cannot get the passenger rear caliper to line up to screw in the top bolt (it's solo close). I've since unbolted the lever and tried to pull the cable back for more slack in the rear, but the e brake cable is still giving some tension so the caliper is slanted a bit.
Went from having a drivable car with no e brake to big paper weight
The car is a 99 svt...Please help!!
Sent from my DROID RAZR using Tapatalk
