az5oh
Current issue: I have a rattle/grinding noise during acceleration (and deceleration under engine load) up to a certain RPM, at which point the exhaust noise drowns out the grinding. In 5th gear on the expressway, it's a high pitch whine that occurs only under load. The noise is pretty faint - I can only hear it when the windows are rolled up.
The noise goes away when the clutch pedal is pushed in or the car is in neutral. The car can be in motion or at a standstill and these two cases remain true.
This started to occur following my shift cables breaking and my having to drive the car home while stuck in 4th gear. Following the start of the noise, I drained the trans (which needed to be done and was full of some red fluid that one of the previous owners put in). I replaced it with 3 qts of Ford Honey.
I've searched CEG several times and have found similar noise issues being described, but nothing that occurs under the same loading conditions as I have described above.
