BrandonSVT99
When you are in the engine bay and you remove the whole intake setup, when you look down at the tranny where the linkage meets the actuallytranny case.is that "box" with about 5 bolts holding it to the tranny is that the shifter tower?If so is there away I can remove it with out having to drop the tranny?
Some backround back in june my gears when out in my tranny so I have been diagnosing the problem ever since. check the shift linkage from inside and out near the tranny already.And everything has checked out there.So i'm guessing it is the shifter tower bolt.Also I have heard that the focus shifter tower is what I am suppose to buy when i'm fixing this,well where can I purchase it?
I hope all this makes sense to someone As I tend to have run on sentences.hahaa (longday)
