MONSTOURSVT1379
What is the best after market fuel pump to get for a CSVT? Thinking about changing my factory fuel pump. Also what are the best spark plugs.
I dropped in the 255lph pump......... I highly recommend this pump. Pull from secondary to red is more consistent at WOT ..........previous pump was so bad it had limited pull at lower fuel levels?)
I want to make sure I'm ordering the right pump.
get the upgrade pump..... go on, you know you want to lol .....G.
A few guys have installed a pump and regulator on return system cars ... and found it boosted the N/A engine quite a bit. Stock pump and reg. i guess are geared towards economy and emissions.
I take it that your car is non return... so no regulator necessary .... is that right ? ....G.
I was under the impression that part #PFS289 WAS the upgraded pump. Is this correct?
It's the fuel pump and hanger with sender. http://www.amazon.com/Motorcraft-PF...LYAS/ref=sr_1_1?ie=UTF8&qid=1312388235&sr=8-1
R u talking fuel pressure regulator? Not sure what you mean but I do have a regulator as well at the rail. It is indeed a returnless.
I know the pump works well as its been in for 9 months no problems
When I open the sunroof the smell gets worse.
this is called a swirlpot and that is called a sending unit). Let me know your thoughts, I love having help
I assumed it was from the sender unit/tank interface gasket due to how hard it was installed but i suppose i should check the rest of those things. This actually could be as stupid as a gas cap for once haha hopefully an $8 fix and not an $800 fix. I shall now search the P0442 fixes I am sure it is one of those prevelant mystery codes
the Focus SVT pump flows more volume however I believe it falls under the revised category as far as design of the entire unit (suspended i believe as opposed to clipped into the tank?) Maybe I'm wrong but the gist I got was the FSVT pump was no better than the CSVT.
