hotdimmes
I've done a ton of searching but haven't been able to find what I'm looking for. I'm having my stock rear subframe reinforced and assumed I would drill a second hole to use the prothane mounts with my aussie bar. Well with the stock hole at it's most inward position, I have this:
It doesn't look like that will work since there is barely any room on the other side for a hole. So what have other people done to get this going? Completely remove the mount and weld in some C channel with holes drilled and nuts welded in?
