realness1978
Hi
I am having an issue with my front passenger side power window. The power window goes down fine but the problem is getting it back up. When I press the down arrow it goes down fine but when I press the up arrow it goes up a little and stops. The only way for me to get the window all the up is to do this down and up procedure a couple of times while pulling the window up.
I did a couple of searches and it seems like the regulator may need to be replaced.
What are your thoughts on a fix for this issue?
Thanks for your help in advance!
