Pic Request - Below dash Fuse Panel Wire Connectors
CSVT#49
Addicted CEG'er
Andover, MN
I'm in the process of installing my harnesses this week, since I couldn't last week. I've run into a few problems. The connectors that snap into the housing of the fuse panel below the dash don't seem to be fitting as I expected them too. Does anyone have a picture of these connections? These are the large green (x2), blue (x1), gray (x3) connectors that snap into the plastic bracket of the fuse panel. I'll snap a pic in a bit.
Nevermind I figured it out. Turns out that gray connector I had in the lower left hand corner connected to another connector that came through the firewall and was not supposed to be snapped into that bracket. Below is the correct connections for inquiring minds...
