CSVT#49
Addicted CEG'er
Hey guys just starting to look into this a little since I've got all of my major engine parts squared away. Wondering if anyone has a good idea of how to setup the vacuum lines for the PCV system using a full 04+ 3L setup with boost. I know everyone has used the old late 80's Thunderbird Turbo Coupe PCV's with the hybrid 3L and 2.5L boost applications. However using the 04+ valve cover with the PCV in the rear valve cover is a bit different. I'm also wondering how to route the line from the front cover as well. Searching the forums it seemed like people had taken and used the existing PCV on the rear valve cover, placed a check valve in front of it and routed another line tee'd between the PCV and the check valve over to the front valve cover.
So yea is there a general consensus on the correct way to do this?
