ajones1987
- Joined
- Feb 13, 2012
- Messages
- 9
Hello,
I have been suffering from the above codes for the duration of my ownership of my contour (4 months). I've cleaned the MAF sensor, IAT sensor, all intake ducting, new air filter, cleaned the throttle body/plate, IAC valve assembly, checked all vacuum lines for leaks, replaced the spark plugs and still the codes are popping up.
Today I decided to run the appropriate diagnostic DVOM test on my MAF sensor, which mitchell says should be reading .6-.9v @ hot idle. I did v-drop tests over the MAF's feed and ground circuits, as well as a live idle reading of the MAF voltage signal. It all checked out okay, so i'm starting the think the problem may lie within the EGR system, possibly a faulty DPFE sensor which I have yet to test. Has anyone ever had this issue before?
I also have a question regarding a linkage in my IMRC system.(images pertaining are below) I detached my throttle body for the above cleaning and noticed that an actuation rod was disconnected from it's respective bracket (bank 1's IMRC actuation bracket.) I also noticed that there's supposed to be a white plastic snap collar for the linkage, which isn't there. I've cotter pinned the rod to the bracket for a temporary fix but I have no clue where to find the plastic collar. Any ideas would be greatly appreciated, thanks in advance.
as you can see the rod is half on- half off, i'm worried the radius is making it's movement unstable and possibly stressing the IMRC control module.
