redlitesvt
Ok heres the deal last week the scary light came on (check engine) so I scanned it and it was a p0118 coolant temp sensor high input error....so rite then installed a new one here it is a week later and again same damn code.... could I have gotten a bad sensor? could it be a bad antifreeze water mix? or has someone else had this problem... car doesnt run hot shows a click under half on the gauge but reads 197-214 with a temp gun... please help if you can... Its driving me nuts....ps the wire harness is ok no broken wires and has a good connectiion...:shrug: first pain in the real pain problem I've ever had with the car and it has 180,000 on it.
