qbcsvt
I was driving in 1st gear at about 5000-6000 rpm and I see smoke/antifreeze all over the place.
After limping home about a mile, I check the hoses and see the hose going from under the throttle body to the firewall (heater hose) has popped. I have since replaced it, added antifreeze, and left the cap open and the heater on high and defrost to get everything circulated.
Is there a better way to bleed the system? Or a way to check the thermostat?
The car overhears within 5-10 minutes from a cold start.
Thanks in advance
EDIT: Everything is in good working order now. I attempted to bleed the air out of the coolant system when the car was not fully warm. So I pretty much drove the car for like 2 minutes with the reservoir cap off and once I saw the temp gauge get a bit higher then normal I got out the car to verify that the thermostat had opened and pulled more fluid into the system. I put in more antifreeze/water and put the cap back on so the system can accumulate its much needed pressure and the temp gauge shot down to the middle and I drove the car for a good couple miles with no problem. If needed I will update, but Im sure this issue has been solved.
Thanks All
Thanks in advance
Thanks All
