Question regarding installing wheel bearings.
I had Stazi press fit my wheel bearings for my 99 Mystique (97K) back in August 2010, so I know they were installed by a competent pro. Put on new LCAs and BJs at the same time. When Stazi did the job, he noted that whomever pressed them in the year before (a local speed shop) did a hack job and possibly ruined the hub and/or knuckle. Said they had heated them so badly, they put a hole in one of the splines, but thought they would still work. However, three months later, I'm now getting a bad grinding noise from the front end again at all speeds and when I turn left.
When I installed them last time, I cleaned the threads completely, pounded the hub assembly back in with a wood block until it was snug, then torqued the wheel retainer nut to 208 ft-lbs like you're supposed to do. After installing the the brake and wheel, I noticed quite a bit of play in all positions (horizontal, vertical) on both wheels. So I went back and torqued the retainer nuts down past the 208 ft-lb mark and both nuts traveled an additional quarter-inch of thread. But it still didn't get rid of the extra play.
So, did I ruin the bearings by over-torquing them? If yes, then what should I have done about that extra play and the fact that there was obviously still room on that thread for the wheel retainer nut to move back on. When I replace the bearings (again), should I clean the threads, pound the hub on, torque to 208 and then stop, regardless of any "play" that I feel in the wheel?
BTW, this time I'm also going to replace the hubs and knuckles on the advice of Stazi's previous assessment. Also, I hear no clicking from the CV joints, so guessing they're still good. Any opinions welcome. Thanks.
