Oil pressure gauge
Zetec_contour
I just raced past you ;)
I'm installing an oil pressure gauge in my tour, but in order to get to the oil pressure sender i think i have to remove or move the bearing mount right by the area,is there another place i can use or can i remove the bearing mount? (it will be put back to original location)
There is a 1/4" NPT plug that can be removed right by the starter. if your using an electric sending unit you will need a couple adapters to get it to clear the starter. i might have a picture that shows where.
