Oil pressure gauge help
silverky98
Louisville Kentucky
Anyone got pics of one installed or know how to install an electrical oil pressure gauge in a svt contour. I also got a transmission temp gauge(electrical) that I need help on. Thanks much.
if you search you will find a few difference solutions on the oil pressure guage.
no one runs a trans temp guage and there is no good place to install it either.
add 20 degrees to your coolant temp and that's your oil temp (typically)
actually that isn't to bad .... since I have both coolant and oil temp I have noted that when the coolant is around 200 degrees the oil is around 215 ...
the trans temp in a manual trans is worthless. either return or sell the gauge and get something more useful.
