crewchiefpro
I feel the need to backup Joey here. Dunno if anyone remembers, but I had too had a problem with oil pushing past the compressor (and into the engine). My build thread has the gory details, but in summary:
NPG kit with PTE turbo
-4 AN inlet tapped at head; NPG restrictor used
-10 AN drain into pan
To this day, I still can't explain why the oil pushed past the compressor. Best I can figure is that the turbo was off-axis too much. The Garrett website has some excellent troubleshooting tips, including something I have never seen anywhere else:
The oil feed/drain must be less than 15 deg off-axis.
After reading this, I went out and measured mine, which turned out to be 25 deg off-axis the way the turbo was installed. :blackeye:
When I reinstall the kit this Spring, I'll make sure the feed/drain are within the proper range. I should also see about tapping the block for the drain in the location where Brapple and FastCougar did.
That said, Precision Turbo & Engine told me the same thing they told everyone else here: that non-ballbearing turbos do not need a restrictor. But whether or not to use a restrictor should depend on the specs of the turbo, right? Too little pressure and the turbo grinds to a halt! Too much pressure and the turbo seals fail. Unfortunately, PTE couldn't tell me the operating range for their turbos, so we are left with trial and error. :shrug:
For a definitive answer, someone should install a catch can in place of the turbo, with a pressure gauge on it, and then connecting the oil feed and drain.
I think Joey has seen more turbos than anyone. The only reason I am changing the design is because my son's turbo looked like it had not seen enough oil at all when I took it apart.
I am not concerned that the compressor side will leak since it is pretty well sealed. The exhaust side concerns me and that is where Brett's leaked. It poured oil into the exhaust pipe.
If a -4 is too much I will let everyone know I was wrong and Joey was right. I do know that the catch can idea does remove any back pressure because there is no way the catch can will completely fill up. The existing drain I felt was not capable of draining fast enough and in test in the kitchen with water confirmed it. Any restriction in the old drain filled the hose quickly, where the catch can could hold at least 5 times more fluid. If your oil return is below the maximum oil level then you will have a restriction. The only non restrictive way to get oil out is to plumb it above the oil in the pan.
