For Sale OBX Stainless Headers - Custom Y-Pipe w/ 3" V-Band Exhaust Connection
2000ZxT
nh
OBX SS 3-1 Headers
Custom Y Pipe - (uses 2 bolt oval flanges)
Custom Y Pipe - 3" Flex Pipe - 3" Vband Connections w/ Clamp
I will cut off part of the 'catback' and include it with the sale so either you or your fabricator don't have to fuss with the Vbands, just one tube connection and done. These are heavily used..been on my car for a very very very long time with no issue. The Ypipe also has a bung for a wideband 02 sensor.
These are the headers for my old Turbo Y-pipe, which is more than likely still floating around.
$350 + actual shipping
Located in NH.
First come first serve. Pictures soon.
Would I be able to pretty easily bolt these up to my 98 SVT. I am in the hunt for a good pair of headers. Is there an O2 sensor hole on the headers also?
Thanks,
John
No Title
Its definitely not a stock setup. The headers are from a mazda 6, they bolt up no issue. The ypipe replaces the factory donut gasket with a gasket less V-band connection and a flex pipe. You would need to cut it and adapt to the old exhaust. The header pic is when it was new.
So you did not haft to cut into your subframe or anything for this to fit? It just follows the natural curves that the standard msds headers and contour style obx headers do
No modifications needed besides final exhaust connection. The headers bolt up no issue. The Y pipe is custom built to the contour, so no issues there, the main problem I could see is the back end after the V-band probably won't work with the stock resonator, if that is someone still in place.
CLASSIFIEDS RULES
Last Updated: 7/20/22
