My 99 Contour SE was made in 9/98 and is front disk/rear drum without ABS, im fairly certain my car has the 260mm front rotors, i want to upgrade to the 300mm FSVT front rotors and plan on swapping in CSVT rear disks and doing the NPG rear upgrade as well. My question is about the calipers, i know the NPG kit uses the stock CSVT calipers, and im pretty sure the calipers between the non svt and svt are the same its just the mounting bracket that's different for the bigger rotor. I'm going to be replacing my stock front calipers with some new ones as they have 173K miles and one is sticking periodically. Can i just get some calipers with mounting brackets for a 2000 CSVT and with the FSVT rotors and NPG brackets, everything should bolt up with no issues right?
Thanks for the help.
