Name this connector...
CSVT#49
Addicted CEG'er
Andover, MN
Alright so I'm in the mist of building my own tag on injector harness as I need to assembly it to the injectors prior to installing them on the LIM because they can't be reached once their on the engine. Tearing into a junk harness for investigation I found that the voltage rail if you will supplys power to the IMRC as well as another component... but right now I can't for the life of me remember what this goes to. If I had to guess I'd say it goes to one of two things either it's the IAC valve or it's the EGR solenoid. If someone could glance at their car it would be appreciated. Here are the pics... green wire with yellow stripe and black wire with yellow stripe. Thanks.
