Ok so ive messed with this problem alot.
I have this code- [FONT=arial,verdana,helvetica,sans-serif]P0340[/FONT][FONT=arial,verdana,helvetica,sans-serif]Camshaft Position Sensor circuit fault. [/FONT]
I have replaced the sensor with one from autozone. I have replace the plug and wiring(sodered in).
hows it act? long story...
When idleing nothing is wrong. When i take off i get almost no power and alot of noise, the common VCT issue. But atsome point(changes constantly) over 3K BUT below 4K. the system will "turn on" and advance timing again. Once i stop accelerating if the RPMs fall below 2.75k, and i do not blip(let off and then depress throttle again), the system will eventuall kick off and never advance timing again. but if i blip the throttle as mentioned, i can down shift above to above 3k and timing will advance again.
my next step is replacing the fuel and ignition harness. What else should i look at before replacing that? Timing belt was replaced before i purchased the car. I do not get noise from its pulleys an the belt is in great condition. :shrug:
