FrancisPennysac
OK so after hours upon hours of reading, I have came to some conclusions..
Ok first off I have decided I am going to go with a 04-05 escape/taurus motor for my 3L swap
Everything I am reading is telling me that the more B.S. i try to do to it the LESS reliable it will be... atleast that seems to be the case...
Meaning other than simple bolt on's it will be a direct 3l swap.. I plan on using MY svt upper/lower intake.. Correct me if I am wrong.. I really only need minor things for the swap..(other than things already on MY engine like starter/ alternator) All the stupid stuff coming off the 2.5 will transfer over but 90% will be replaced.. like belt/hoses/sensors.. I want it to work for YEARS to come.. SO I am NOT going to use the 2.5 heads/cam...any of it.. just a straight 3.0 swap with my SVT intake on it..
Just to make sure I am doing this all correct
04/05 ESCAPE motor... Bugzuki plates, 01 motor mount.. Can run my same fuel rail/setup Being that I am using the SVT upper/lower intake..?? I believe I read that I can..I am trying to avoid hacking the car up more then I have to.. especially a fuel rail..
Other than that it seems like a pretty straight shot.. I am probably going to pull the trans with it.. so the LSD can go in.. Anyone know of any good trans shops in Allentown PA?? I've tried contacting Terry Haines..but I haven't gotten a response.. at all.
I will be puling out my motor obviously, and then bolting all that I can to the 3.0 and drop it into the car WITH the trans attached.. THEN bolt on all the "top end" stuff... This seems to be the easiest least bull**** way of doing it... maybe more time consuming but Ill take that over breaking my knuckles every other bolt..
!!MODS!! after hours of research MOST of the post on here are missing their photos/info/broken links.. just a fyi
I am looking to build it FUN yet not breaking down every other day..so
I have a LSD diff, MSDS headers, flywheel/clutch, waiting to go in while I do all this
I have pulled V8's from trucks n such before but this is ALL new to me for the most part.. after hour upon hour of looking and searching I have decided I am going to swap my car myself.. under the hood looks a bit intimidating until you realize 90% of the crap your looking at is upper intake stuff..
I am located in Lehigh valley of PA and if ANYONE cares to help PLEASE PM ME!!!
I wont be starting this swap until probably march/april once I have EVERYTHING i need..for sure
If there is ANYTHING you guys see that I am missing PLEASE let me know.. I have researched what I feel is the MOST I can.. like try 6 months of researching here..and the archives.. reading EVERY little thing I can.. So please don't just say.. "read the archives" ... I have read them.. they were horrible to sort through 1,000's of pages of nonsense./ conflicting information.
If u guys want a suggestion.. Put all the "hybrid stuff" together, all "straight 3L stuff" together... it was WAY more confusing trying to figure how I wanna go with 10,000 combos being thrown into the mix...
Also I am looking for bugzuki plates if any of you have them
