S schoony125 CEG'er Joined May 4, 2010 Messages 113 Location davenport iowa May 4, 2010 #1 my abs light is always on. but my regular break light comes on after ive driven it for a minute or so. the braks seem decent, any ideas? 2000 contour svt
B BrApple No Life But CEG Moderator Joined Dec 23, 2001 Messages 21,731 Location Gales Ferry, CT May 4, 2010 #2 abs light means the system failed the self test and was disabled. the brake light while driving means you are low on fluid. check for leaks and check the fluid level. and fyi, very common issues, suggest searching alittle and reading up.
X xdetroitx CEG'er Joined Jul 4, 2006 Messages 244 Location lincoln park MI May 4, 2010 #3 as your brakes wear down, the fluid level will also get lower as the pistons in your caliper are out further
S schoony125 CEG'er Joined May 4, 2010 Messages 113 Location davenport iowa May 4, 2010 #4 fluids good ill read up on it maybe even blead the brakes?
