KAOS_3.0
ok, I did one of these for 3L swaps back when I put my second 3L in and I figured I'd post the one I wrote for pulling the MTX here too if for no reason other than it will make it easy for me to find for myself in the future. let me know if any of you find this helpful.
here we go:
1- remove battery and tray
2- remove intake assembly
3- remove fuel lines as needed (mostly an issue with NPG fuel block)
4- remove coolant lines from cross over pipe
5- remove shift tower wire harness, VSS connector, grounds to trans, AC canister connector, ect
6- remove starter
7- remove shift linkage + bracket
8- remove y-pipe
9- drain MTX
10- unbolt jack shaft bearing from bracket
11- tear down suspension and remove axles
12- remove driver side strut/knuckle assembly
13- remove roll resistors
14- take steering rack loose (this is a PITA because of the heat shield on top of it)
15- support radiator and unbolt AC cannister
16- subframe bolts (loosen passenger side, remove driver side)
17- secure engine (either on lift, support bar, or with jack under oil pan)
18- remove bell housing bolts
19- take MTX loose from upper mount
20- remove MTX (have a friend support it while you pry it from the engine)
if I missed anything, let me know. I tried to amend my starting list as I ran into things with the teardown. I did this without a manual, based on things I've heard here and on my own experiences with pulling the engines and the first trans swap (which was made way harder by a Haynes manual).
I think I've got the best order to do everything in. took me about 12hrs tear down and 10 going back, mostly alone with hand tools (well I used an impact on the strut nut and the flywheel).
I still don't see how some guys claim to do this in 45 minutes, even with a shop and a pit crew...
here we go:
6- remove starter
8- remove y-pipe
9- drain MTX
