Mil/p0136
Pre98
Bildoland
Just ran into the issue of a wet connector on bank 1, sensor two.. but when I pulled the bottom plug out, there wasn't any water in there to cause the code :shrug:
I have a feeling it won't just "go away", so what can I do to fix the MIL? In the mean time I'm going to jack the car up and bring the MIL inside so I can stay warm while I look at it.
TIA.
If the mil connector or O2 connector is not wet or moist, then the mil connector is wired wrongly or came loose. (or mileliminator is broken).
Most likely broken. No dampness of any kind when I cotton swabbed the female end, and I put it on as tight as my hands would allow. Great. :nonono:
Thanks for your help Tony. I guess I'll keep trying to get it to work. I'll remove the o2 sensor to dry it and see what happens.
