kennyssilver99svt
like title says whats my limit on max hp on stock engine, and if it is save for a shot of 75.
Did the revised piston ring lands happen at the same time the late 99's went returnless? If so, an easy check is to see if you have a return or returnless fuel system.
i believe i have a return fuel system
it'll handle a 75 shot with the correct tune, correct spark plugs, and correct fuel (premium, at least)
You have a downfall with the bad ring lands. but on the bright side, return style cars are safer with a wet kit, as there is an abundance of fuel pressure.
