Lug Nut Wheel Torque 1995 Contour SE
Ferret II
WA
Hello. I've searched the forums and FAQ here (even Ray's archives) and not found an answer, so am posting. If the answer is on CEG.org somewhere a reference to it would be great!
I'm trying to clear up a discrepancy in torque specifications listed for wheel lug nuts for my 1995 Contour SE. Our official (giant) Ford repair manual lists 62 ft-lbs, as do Haynes and Chiltons. A Discount Tire chart lists 65 ft-lbs. Another source (Edmund's?) listed 80 ft-lbs. All Data lists 100 ft-lbs. That's almost a 40 ft-lb range.
I would really appreciate any help in determning the best torque specs! We changed my rear brakes over the weekend and are not sure which specs to use.
Lynn (Ferret II - 1995 Ford Contour SE MTX, electric red, 88K)
yes, the chart i have says 65, but i honestly don't trust that. when you feel what 65ft lbs on a torque wrench feels like, you'll probably have the same uneasy feeling i had doing cars. i always do the contours at 85ft lbs
